This handy accessory turns an ordinary motor into a bench mounted drill. Just attach this adapter any 1/2" right threaded shaft or one of our shaft extenders. The Chuck Adapter is seen here fitted to a shaft extender.
Really great chuck.
These chucks are made well, and fit the 1/2-20 thread of the RH arbors. The farther you thread it on, the more the jaws close, so no key is required.
