EXTRA LONG SHAFT EXTENDER LH 5/8"
Designed especially for larger buffing & polishing units.
The wide shoulder provides plenty of clearance plus ample space for easy movement & positioning of work pieces.
Slides onto 5/8" diameter shaft and tightens with two grub screws.
Great for mounting larger sized wheels. 6-1/2" Long. Threaded section is 2" long. Fits 1/2" Wheel Holes
Works well
It's done everything I needed it too so I have no complaints. I'd definitely recommend it to a friend that needed some.
Well made. Good price. Delivered in good time.
I purchased this product recently and have found it to be well made. The adapter is one piece steel. The set screws seem a bit small however they have worked well so far. The included washers are Thick machined pieces not stamped like the washers in the picture. The included nut is a bit narrow but, again , it has worked well so far. The adapter is not zinc plated as seen in the picture. It has a black coating that may allow the adapter to rust so I have wiped mine down with a rust inhibitor. I had to shim my adapter to get it to run true. That is not unusual as the adapter has the clamping force coming from one side of the boar. Your mileage may vary. I would recommend this product to a friend.
