This handy accessory fits a 5/8" shaft to extend the stubby shaft out 3" further from the motor body. Shaft size = 1/2" diam. The adapter will fit buffing wheels up to 1 inch thick |
9 Reviews Hide Reviews Show Reviews
great product, great price!
we are impressed with this little item! easy to install and made well. perfect for it's intended use.
Great
We needed this to polish our 1965 Airstream Trailer. It is working great.
Great Tool!
Adapter threaded on great.
Perfect Adapter
This is the ideal tool for using your buffer to polish metal with buffing wheels. Threads onto standard buffer threads and the length extends the buffing away from your buffer. This gives you the exact clearance and balance to make the job much easier to perform. Perfectly designed tool, and even better customer service. Thanks so much, Caswell.
Nice
Well made adapter and better price than others I've seen out there.
Quality adapter
About the only thing I wish is that it would have a longer bolt to accept more wheels.
Tool works great!!
Would buy again!!
okay
good service good price
adapter
Very good idea i use it almost every day
