Designed especially for larger buffing & polishing units.
The wide shoulder provides plenty of clearance plus ample space for easy movement & positioning of work pieces.
Slides onto 1/2" diameter shaft and tightens with two grub screws.
Great for mounting larger sized wheels. 6-1/2" Long. Threaded section is 2" long. Fits 1/2" Wheel Holes
Nice extender
Well built and affordable. I do sometimes end up with a wobble but I attribute that to my grinder
very nice tool
I like the length of this adapter and it is made very well (true on axis and stout) compared to other similar adapters I have purchased.
