FLAPPER ADAPTER - STANDARD - STAINLESS
The Flapper Adapter mounts onto any angle grinder with a 5/8 - 11 shaft (almost all grinders), and allows you to mount any wheel with a 1/4" shaft onto your angle grinder. Mount flap wheels, cutoff wheels, buffing wheels, grinding wheels, carbide burrs etc.
Made in the USA. 303 Stainless body with Tool Steel Collets, 1/4" Collet, and Nut.
excellent component
This device converts a typical angle grinder into a die grinder / pad sander that takes the place of a noisy air die grinder. Absolutely worth the price! Lou W., Fairfax Va.
