null
Get Our Booklet
Polishing
Download our FREE How To Buff & Polish Booklet and learn how to use these products.
  • DOMET FLANNEL WHEEL - 4" X 1/2"
    Domet flannel is very the softest available material, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the...
    $3.84
    Choose Options
  • DOMET FLANNEL WHEEL - 6" X 1/2"
    $4.94
    Choose Options
  • DOMET FLANNEL WHEEL - 8" X 1/2"
    $6.04
    Out of stock
  • EXCELLO SS COMPOUND (MED GREASY)
    STAINLESS STEEL BUFFING WHEEL BAR COMPOUNDS FOR STAINLESS OR COLD ROLLED STEEL Stainless Compound is made of "alumina" and grease binders. Developed for use on stainless steel, its fast cutting and good coloring properties are also a favorite for buffing...
    $21.49
    Add to Cart
  • EXPANDER SANDING WHEEL
    Cleverly designed to accommodate a sanding belt, the Expander Sanding Wheel allows the user to sand large areas quickly and uniformly. Ideal for sanding engine castings to remove the sand mold marks prior to polishing. The center of this wheel has...
    $41.73
    Out of stock
  • EXTRA FAST CUT SS COMPOUND (MED DRY)
    $21.49
    Add to Cart
  • EXTRA LONG SHAFT EXTENDER 1/2 RH
    Designed especially for larger buffing & polishing units. The wide shoulder provides plenty of clearance plus ample space for easy movement & positioning of work pieces. Slides onto 1/2" diameter shaft and tightens with two grub screws. Great for...
    $33.12
    Add to Cart
  • EXTRA LONG SHAFT EXTENDER 1/2" LH
    $33.12
    Add to Cart
  • EXTRA LONG SHAFT EXTENDER LH 5/8"
    Designed especially for larger buffing & polishing units. The wide shoulder provides plenty of clearance plus ample space for easy movement & positioning of work pieces. Slides onto 5/8" diameter shaft and tightens with two grub screws. Great for...
    $33.12
    Add to Cart
  • EXTRA LONG SHAFT EXTENDER RH 5/8"
    $33.12
    Add to Cart
  • FAST CUT GREASY TRIPOLI COMPOUND
    This is a greasy, extra fast cutting grade of Tripoli containing a high percentage of aggressive abrasives combined with Tripoli Powder, which produces a fastercutting action. Used extensively on heavy buffing work and all types of automatic buffing...
    $15.80
    Add to Cart
  • FAST CUT SS COMPOUND (MED GREASY)
    $21.49
    Add to Cart
  • FELT WHEEL - HARD 6 X 1
    Ideal for many uses including woodworking, gunsmithing, knife sharpening, jewelry work etc. These firm felt wheels won't splay out or fray, making them ideal for the applications above. Long lasting and quick working. Use with white compound for most...
    $36.29
    Out of stock
  • FELT WHEEL - MEDIUM 6 X 1
    $30.24
    Add to Cart
  • FLAP WHEEL 120 GRIT 1 X 1
    These tightly packed and bonded sheets of resin bonded aluminum oxide are great for sanding, shaping and polishing all types of materials. Especially good for removing paint and rust. 1/4" shank works in any drill, drill press, flexible shaft, lather etc...
    $7.58
    Add to Cart
