FAST CUT GREASY TRIPOLI COMPOUND
This is a greasy, extra fast cutting grade of Tripoli containing a high percentage of aggressive abrasives combined with Tripoli Powder, which produces a faster
cutting action. Used extensively on heavy buffing work and all types of automatic buffing machines.
2" X 2" X 10" Bar
all worked out for the best
I originally meant to order the standard brown tripoli compound, instead I got this. This stuff is great! I find mine cuts a bit faster than my emery does on steel. It was VERY fast on brass, yet left a really nice shine. This is good stuff, I recommend it. the bar is HUGE!
Beats regular tripoli
Not only cuts faster but lasts long..give it a try
