FELT WHEEL - HARD 6 X 1
Ideal for many uses including woodworking, gunsmithing, knife sharpening, jewelry work etc.
These firm felt wheels won't splay out or fray, making them ideal for the applications above.
Long lasting and quick working. Use with white compound for most metals and wood, blue or red for fine jewelry.
Wheels have a pinhole center. Use with a Tapered Buffing Spindle
Excellent
I use the 6" X 1" hard felt wheel to sharpen my carving tools. I have not found anything that does as good a job asthe harde felt wheel. I highly recommend this product. Ray
