DOMET FLANNEL WHEEL - 8" X 1/2"
Domet flannel is very the softest available material, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the most delicate items such as silver and gold plate. This wheel should not be contaminated with any other compound.
4 Reviews Hide Reviews Show Reviews
Best finishing wheel
Absolutely the best final polishing wheel I have found!
Soft and smooth for the next-to-last compound.
These are used with the "extra fine" compound to bring up the shine on my guitars. They really make a great difference!
Great for that final glowing polish look
Find this to be a great final buff for anything that I want to really shine.
Eyerything went great !
Buffing wheels are great!
