FLAP WHEEL 120 GRIT 1 X 1
These tightly packed and bonded sheets of resin bonded aluminum oxide are great for sanding, shaping and polishing all types of materials.
Especially good for removing paint and rust.
1/4" shank works in any drill, drill press, flexible shaft, lather etc.
Timesaver
Saves time cleaning castings.
