Cleverly designed to accommodate a sanding belt, the Expander Sanding Wheel allows the user to sand large areas quickly and uniformly. Ideal for sanding engine castings to remove the sand mold marks prior to polishing.
The center of this wheel has special adapters to fit shafts of ½€, 5/8€, ¾€ & 1€ diameter.
The wheel has a 6 inch diameter, with a 1.25 inch face. The wheel does not include any belts.
Max RPM 2800
Our Aluminum Oxide sanding belts fit all other brands of expanding wheels.
13 Reviews Hide Reviews Show Reviews
Simply the best
I love all of Caswells products and the staff are so knowledgeable. This expand-er wheel can not be beat for the price. Now if the would get the 8" x 3" wheel with the bands my kit shop would be complete.
expander wheel
Works great on my 3200 rpm buffer
expander wheel
Expander wheel
Great wheel. Works well on my 3200 rpm machine
expander wheel
very good 1/2 the price for the same item at another site
Good Product
This is a great product and is everything I hoped it to be. The shipping time was fast and I'm a happy camper.
Good Product
Missing the bushing.
I wrote tech support and they sent the bushing...
Good product
I was glad to find your expanding sanding wheel priced below other competitors. Its nice to find one that's affordable.
