STAINLESS STEEL BUFFING WHEEL BAR COMPOUNDS
FOR STAINLESS OR COLD ROLLED STEEL
Stainless Compound is made of "alumina" and grease binders. Developed for use on stainless steel, its fast cutting and good coloring properties are also a favorite for buffing all types of steel.
To remove sanding scratches from stainless, start out using a sisal buffing wheel with the Super Sisal Compound #F515-6154. You can then work your way up to a spiral sewn cotton buff using the All Purpose Stainless Compound, F-515-6147.
For a final high luster finish, use a loose cotton buffing wheel or canton flannel buff with the F515-6113 White Lightning Rouge.
2" X 2" X 10" Bars
buffing stainless
good stuff
as described
Fast and easy shipping
