Domet flannel is very the softest available material, and this wheel is loosely stitched, so the layers of cloth flare out to give a wide angle ultra smooth polishing surface. Generally used with the BLUE or RED compound, this wheel can be used on the most delicate items such as silver and gold plate. This wheel should not be contaminated with any other compound.
Best finishing wheel
Absolutely the best final polishing wheel I have found!
buffing wheels
I use for buffing my lathe turnings and they work great.
