null
Get Our Booklet
Polishing
Download our FREE How To Buff & Polish Booklet and learn how to use these products.
  • TREATED SPIRAL SEWN BUFFING WHEEL - 6
    These buffs are specially treated to give longer life than standard buffs. This treatment makes them much harder than regular cotton buffs, which allows the user to exert more pressure onto the wheel and gets the job done faster. Use with any compound...
    $9.89
    Choose Options
  • TREATED VENTED BUFFING WHEEL - 4
    These buffs are specially treated to give longer life than standard buffs. They cut and color faster and are vented to keep the workpiece cooler. Hard center allows fast mounting to tapered spindel for quick change. Use with any compound.
    $8.79
    Choose Options
  • TREATED VENTED BUFFING WHEEL - 6" X 1/2"
    $9.89
    Choose Options
  • TREATED VENTED BUFFING WHEEL - 8
    $12.09
    Choose Options
  • UNTREATED VENTED BUFFING WHEEL - 6
    The folded pleats hold more compound and keep the part cooler, resulting in a being twice as fast as a Spiral Sewn wheel. 10" wheels require 3" washers. These wheels are softer than their yellow cousins.
    $8.79
    Add to Cart
  • VIBRATORY TUMBLER - ADJUSTA-VIBE 18
    Heavy duty & adjustable for all medias The AV-18 has capacity of .18 cubic feet (5.3 Quarts). It has adjustable amplitude and is designed for heavy duty use with all medias. The 12-inch bowl is equipped with drains. This model has many features of our...
    $626.18
    Add to Cart
  • VIBRATORY TUMBLER - ADJUSTA-VIBE 40
    Compact with adjustable amplitude Model 40 vibratory machines are compact, yet have a capacity of .35 cubic feet (10.4 quarts) and are equipped with amplitude adjustment, inlet and outlet ports for compound rinsing systems and heavy duty cross-linked...
    $1,480.05
    Add to Cart
  • VIBRATORY TUMBLER - ADJUSTA-VIBE 75
    Heavy duty & adjustable amplitude The AV-75 is a .75 cubic foot (5.6 Gallon) capacity machine that offers increased productivity over other models. The machine is equipped with a heavy duty drive system that includes amplitude adjustment and the same ...
    $1,802.63
    Add to Cart
  • VIBRATORY TUMBLER - TUMBLE VIBE 10
    Heavy duty finishing & rinsing The industrial model TV-10 has heavy duty drive and suspension combined with a tough, cross-linked polyethylene 10 inch bowl. Bowl capacity is .10 cubic feet (35 to 40 rings), has a noise reducing lid and a liquid drain...
    $302.34
    Add to Cart
  • WHEEL CLEANING BAR
    WHEEL CLEANING BAR
    Restores clogged, loaded and glazed abrasive belts and buffing wheels, by removing embedded grinding debris lodged and packed between the abrasive grit particles. Works like a giant eraser. Simply hold and press the cleaning bar firmly against the...
    $26.55
    Add to Cart
  • Wheel Rake (Complete Unit - Handle & Teeth)
    Our wheel rakes make cleaning your buffing wheels easy. Offer the jagged blade to the edge of the spinning wheel, and work it across the face until the wheel looks bright and fluffy once more. This action, done periodically, will remove entrapped metal...
    $27.82
    Add to Cart
  • WHEEL RAKE TEETH
    WHEEL RAKE TEETH
    $13.90
    Add to Cart
  • WHITE BUFFING COMPOUND JUMBO
    Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The...
    $18.96
    Add to Cart
  • WHITE BUFFING COMPOUND LARGE
    $12.64
    Add to Cart
