These buffs are specially treated to give longer life than standard buffs. They cut and color faster and are vented to keep the workpiece cooler. Hard center allows fast mounting to tapered spindel for quick change. Use with any compound.
3 Reviews Hide Reviews Show Reviews
Excellent wheel
These treated vented wheels are more durable and long lasting than a standard wheel. Work great for smoothing aluminum after initial sisal cut.
Love the treated wheels
Works great
Good quality
Will buy this again
