WHEEL RAKE TEETH
Our wheel rakes make cleaning your buffing wheels easy. Offer the jagged blade to the edge of the spinning wheel, and work it across the face until the wheel looks bright and fluffy once more. This action, done periodically, will remove entrapped metal particles, which could scratch a more delicate part.
11 Reviews Hide Reviews Show Reviews
WHEEL RAKE TEETH
Nice sharp rake. I got the one without a handle. Mounted it on a heavy 12x12x2 piece of fir. Better for hand buffer that way since I only have two hands.
Does the job
Does the job
Great
As described
WORKS WELL
GOT IT WITHOUT THE HANDLE AND IT WORKS GREAT
Build your own
I already have one rake but needed another since I often work in two different locations. save some money and build your own
Spares are nice to have.
I always keep a spare just in case.
Excellent as Always...Thanks
Great Quality
I got just the rake without the handle, then cut a handle out of some scrap hardwood. Works great, very strong.
great quality.......
perfect for making or replacing the teeth on your rake...........
