These buffs are specially treated to give longer life than standard buffs. This treatment makes them much harder than regular cotton buffs, which allows the user to exert more pressure onto the wheel and gets the job done faster. Use with any compound just like standard spiral sewn wheels.
Love the treated wheels
Great for red rouge
Treat wheels work perfect!
Using these as cutting/polishing wheels on aluminum boxes. They work great and do not wear out too fast
