VIBRATORY TUMBLER - TUMBLE VIBE 10
Heavy duty finishing & rinsing
The industrial model TV-10 has heavy duty drive and suspension combined with a tough, cross-linked polyethylene 10 inch bowl. Bowl capacity is .10 cubic feet (35 to 40 rings), has a noise reducing lid and a liquid drain. Do not run steel shot or ceramic media in this machine; doing so will void the warranty. CE Listed
115V AC Input. 230V AC Available. Call for details.
Shipping Weight: 12 lbs, 1.05 cubic feet
Read About Vibratory Tumblers and Media Selection Here
