Compact with adjustable amplitude
Model 40 vibratory machines are compact, yet have a capacity of .35 cubic feet (10.4 quarts) and are equipped with amplitude adjustment, inlet and outlet ports for compound rinsing systems and heavy duty cross-linked 17-inch polyethylene bowl. Noise reducing lids are standard. CE Listed
115VAC Input. 230VAC Input available. Call for details.
Shipping: 51 pounds, 5.06 cubic feet
Read About Vibratory Tumblers and Media Selection Here
