| Our buffing and polishing compounds are manufactured from high quality ingredients, designed for the industrial plater/polisher to obtain fast exceptional quality finishes. The Jumbo bars are approximately 2" x 2" x 8" & weigh approx. 3 lb. each. The large bars are 1.25" x 1.25" x 6" and weigh approx. 1.5 lb. each. We believe these industrial size bars represent a better value than the packaged tubes being marketed. |
4 Reviews Hide Reviews Show Reviews
Great finisher
After using the green compound to develop most of the shine on my stainless project, this compound on a loose cotton wheel added a little extra brilliance to the finish. Very pleased with the result.
Quality compound
Nice even consistancy! I've used other brands and have had inconsistant chunks of abrasive. Not the case with this stuff.
professional grade
Another fine Caswell professional grade product.
Replacement Compound
Finally needed more. Great Shine.
