Heavy duty & adjustable for all medias
The AV-18 has capacity of .18 cubic feet (5.3 Quarts). It has adjustable amplitude and is designed for heavy duty use with all medias. The 12-inch bowl is equipped with drains. This model has many features of our larger machines for processing metal parts, whether for deburring or polishing. CE Listed
115V AC Input. 230V AC available. Call for details.
Shipping: 13 pounds, 2.13 cubic feet
