WHEEL CLEANING BAR
Restores clogged, loaded and glazed abrasive belts and buffing wheels, by removing embedded grinding debris lodged and packed between the abrasive grit particles. Works like a giant eraser. Simply hold and press the cleaning bar firmly against the running wheel, for a few seconds, until loaded particles have been removed
great stuff
first time I've tried this type of product,really helps clean the wheels
