UNTREATED VENTED BUFFING WHEEL - 6
The folded pleats hold more compound and keep the part cooler, resulting in a being twice as fast as a Spiral Sewn wheel. 10" wheels require 3" washers. These wheels are softer than their yellow cousins.
3 Reviews Hide Reviews Show Reviews
Nice wheel
Can be used for cutting and/or polishing, fast working and long lasting.
Works great
Great wheel for polishing
Good quality
Will buy this again
