TREATED VENTED BUFFING WHEEL - 8
These buffs are specially treated to give longer life than standard buffs. They cut and color faster and are vented to keep the workpiece cooler. Hard center allows fast mounting to tapered spindel for quick change. Use with any compound.
Versatile Wheel
Have used this buff for aluminum and stainless on beginning buff stage and have had fast pleasing results.
Excellent wheel for rough cut on alluminum
First time using this wheel and very satisfied with results. Using this wheel to buff aluminum with brown compound and it works fantastic-would definitely buy again.
