Heavy duty & adjustable amplitude
The AV-75 is a .75 cubic foot (5.6 Gallon) capacity machine that offers increased productivity over other models. The machine is equipped with a heavy duty drive system that includes amplitude adjustment and the same features as the AV-40. 21-inch diameter bowl. CE Listed.
115VAC Input. 230VAC Input available. Call for details.
Shipping Weight: 61 pounds, 9.18 cubic feet
Read About Vibratory Tumblers and Media Selection Here
