Rose Gold Brush Plating Solution
For use with brush plating systems, including our Plug N Plate System. Use at 4.5-6 volts DC.
Cyanide Free.
Contains over 1 pennyweight of gold per 4oz of solution, (2 troy oz per gallon) which enables the solution to plate an even layer of gold as quickly, if not more quickly, than any cyanide based product.
