The great new way to brush plate small parts
Video: Title
Using The Caswell Plug N Plate Brush Plating Kit
Read An Article From Mac Life Magazine On Plating An iPod Using Our Plug N' Plate® Kits (372 KB PDF)
Read the Instruction Manual Here
4 Simple Steps To Brush Plate Your Small Parts
1. Plug In The Adapter | ![]() |
2. Clip the Black Lead To The Part | ![]() |
3. Soak The Wand With Bandage In the Solution | ![]() |
4. Brush The Wand Over The Cleaned Part | ![]() |
Plug N' Plate® is a new concept in plating small parts. Our unique mains power pack supplies just the right amount of power allowing you to brush, and in some situations, dip plate your smaller components.
The Plug N' Plate® system will also allow you to patch repair areas where the original plating has worn away.
Plug N' Plate® is ideal for vintage vehicle restorers, antique collectors and dealers, and small workshops doing prototype work.
What could be simpler? The Plug N' Plate® wand is attached to the red plug on the Power Pack, and the alligator clip is attached to the work-piece. The end of the wand is covered in an absorbent bandage, which is soaked in the plating solution for a few seconds.
By simply stroking the part with swift brush strokes, the circuit is closed and the plating metal bearing solution goes to work, depositing its beautiful layer onto the object.
Plug N' Plate® is perfect for gold plating car emblems. Simply strip the chrome off with Chrome Stripper, then apply the gold. Full instructions are included.
Plug N' Plate® may be applied onto most metals. To see which kit plates onto which metal, read our instruction booklet. To plate onto Stainless Steel, use the Plug N' Plate® Copper system. When gold plating onto stainless, apply our Stainless Steel Activator For Gold with a stainless wand and 4.5V power pack, then you may gold plate directly onto the stainless part.
Aluminum can be plated with the Acid Copper Plug N Plate system, after prepping your part with Zincate.
Plastic parts can also be plated with our Acid Copper Plug N Plate system after painting with conductive paint and swabbed with Tinning Solution.
* - Manufacturer Direct Pricing. Plug N' Plate® is a registered trademark of Caswell Inc.
Plug N Plate Gold Kit Contains:
- 1 x Plug N' Plate® 4.5V Power Supply
- 1 x 4oz Gold Solution
- 1 x SS Brush Plating Wand
- 1 x Wand Bandage
- 1 x Instruction Booklet
- Free Technical Support
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
GHS Info
SDS
16 Reviews Hide Reviews Show Reviews
Easy & fast shipping
Kit arrived fast, I read instructions and was pro plating in no time,love this kit
Package arrived quickly and in good condition
Product was as described easy to use and wife was happy with the results. Will buy again
Great Gold Plating Kit
This is a fantastic 24 ct gold plating kit. It allowed me to fix a ring that I thought was a loss.
Perfect
I am a Big fan of this kit ( gold plating kit ). Used it to gold plate keys and love bracelets bangle, Worked very well. Called support for questions prior to purchase. Representative was knowledgeable and the conversation was actually quite stimulating as he went through the process and the chemistry behind the process with me. Impressed by this company. Even more impressed by this product. If you're brushing on small items, even keys, I would suggest looking into the nubby wand attachments they carry to ease in the detail of the process. Can't wait to try some other metal kits! Thanks.
great. nice kit.
I have already gold plated gun triggers, bolts and accys.and, I have copy chrome plated many bolts and screws for my Harley. I love it!!!
Plug N' Plate® Gold Kit
Very easy and effective. Good Quality
great product
satisfied with process
Gold plating kit
I used this gold plating kit for my religious medals. Very satisfied with this product. I highly recommend it to Anyone, who likes to electroplate. I also made a purchase for 24 karat fast gold, about two years ago. Did plenty of plating with 4 oz's I purchased. Thanks Caswells
Perfect
Exactly what I needed! Works quickly and exactly as described. No confusing instructions or anything. Would definitely recommend to others.
