PLUG N' PLATE GOLD SOLUTION
Gold Plate car emblems, antiques, jewelry, coins, keepsakes, etc. Almost anything can be replated providing there is a nickel base. (Chrome plate has a nickel base). Gold solution has 4 month shelf life.
GHS Info
SDS
23 Reviews Hide Reviews Show Reviews
use for replacing worn off places on gold filled watches
I've used this for several years not to re-plate places on pocket watch cases that are worn to the brass. simple to use with excellent results. Donna
Great Solution
The solution itself is great, and so is the customer service! Just wish there were a way to do it without having to clip anything to the piece being plated, as I use it for jewelry and don't want it to scratch.
Couldn't be easier to use.
Used this to gold plate some sterling silver rings I had. Read the directions and practiced on a quarter first. Using the dip instructions, it was easy (especially after I first heated the solution).
very good product
Works really good
very good product
Works really good
very good product
Works really good
Gold Plug and Plate
used for many years and great results. I learned that over nickel you really have to to get the finish clean and recommend their Flitz with a rag and brush and then use nickel cleaner solution and then very durable
GREAT
I use this to plate my microphone top. Looks fantastic and last a very long time. Gold cleans like no other metal and the Bling factor has become somewhat of a signature. Easy and quickly finished for about 3 years of heavy touring.
GREAT
