Plug N' Plate Gold Emblem Plating & Stripping Kit
Everything You Need To Gold Plate Car Emblems
Includes Gold Plating System, Chrome Stripper and Nickel Activator
Video: Title
Using The Caswell Plug N Plate Brush Plating Kit
Read An Article From Mac Life Magazine On Plating An iPod Using Our Plug N' Plate® Kits (372 KB PDF)
Read the Instruction Manual Here
Most car emblems are chrome plated plastic. This kit allows you to strip the chrome off, by reverse plating with the chrome stripper, which exposes the nickel plate that is under it. Activate the nickel plate with the included activator, then use the gold plating solution to plate the nickel.
4 Simple Steps To Brush Plate Your Small Parts
1. Plug In The Adapter | ![]() |
2. Clip the Black Lead To The Part | ![]() |
3. Soak The Wand With Bandage In the Solution | ![]() |
4. Brush The Wand Over The Cleaned Part | ![]() |
Plug N' Plate® is a new concept in plating small parts. Our unique mains power pack supplies just the right amount of power allowing you to brush, and in some situations, dip plate your smaller components.
The Plug N' Plate® system will also allow you to patch repair areas where the original plating has worn away.
Plug N' Plate® is ideal for vintage vehicle restorers, antique collectors and dealers, and small workshops doing prototype work.
What could be simpler? The Plug N' Plate® wand is attached to the red plug on the Power Pack, and the alligator clip is attached to the work-piece. The end of the wand is covered in an absorbent bandage, which is soaked in the plating solution for a few seconds.
By simply stroking the part with swift brush strokes, the circuit is closed and the plating metal bearing solution goes to work, depositing its beautiful layer onto the object.
Plug N' Plate® may be applied onto most metals. To see which kit plates onto which metal, read our instruction booklet. To plate onto Stainless Steel, use the Plug N' Plate® Copper system. When gold plating onto stainless, apply our Stainless Steel Activator For Gold with a stainless wand and 4.5V power pack, then you may gold plate directly onto the stainless part.
Aluminum can be plated with the Acid Copper Plug N Plate system, after prepping your part with Zincate.
Plastic parts can also be plated with our Acid Copper Plug N Plate system after painting with conductive paint and swabbed with Tinning Solution.
* - Manufacturer Direct Pricing. Plug N' Plate® is a registered trademark of Caswell Inc.
Plug N Plate Gold Emblem Plating & Stripping Kit Contains:
- 1 x Plug N' Plate® 4.5V Power Supply
- 1 x 4oz Gold Solution
- 2 x SS Brush Plating Wands
- 5 x Wand Bandages
- 8 oz Chrome Stripping Solution
- 1 Pint Nickel Activator
- 1 x Instruction Booklet
- Free Technical Support
Hazardous Shipping Info
GHS Info
SDS
Videos Hide Videos Show Videos
