8 fl oz of stripping solution. To strip anodize, immerse parts for 5-30 minutes. To strip chrome, use a stainless steel wand and 12V DC.Contains Hazardous Goods. Shipping restrictions apply. Ground shipping only to the Continental USA. Please call +1 315 946 1213 or contact us for rates to other locations.
Hazardous Shipping Info
GHS Info
SDS
9 Reviews Hide Reviews Show Reviews
Great product
Works great and easy to use
best stuff
Very happy
best stuff
Very happy
best stuff
Very happy
works great
works just like the directions say.
Great Product!!!
When stripping crome with a wand it almost like painting it off. I thought it would take some work but, it was fast and effortless!
Fantastic
Follow the instructions and the anno is off in a matter of minutes.
It works!
It's good stuff. It strips your anodizing right off. However you can get the same thing elsewhere even locally. I have used it and will use it again. Works awesome, although much faster when hot. Make sure your careful when first mixing with water, it does cause an endothermic reaction.
Anodize Stripper
It works, but I am not sure it works well enough....I had patchy spots in the 2nd anodize coating where the dye did not take very well....great for reverting from an anodized color to a polished or brushed finish though.
