Plug N' Plate Workshop Kit
The great new way to brush plate small parts
Video: Title
Using The Caswell Plug N Plate Brush Plating Kit
Read An Article From Mac Life Magazine On Plating An iPod Using Our Plug N' Plate® Kits (372 KB PDF)
Read the Instruction Manual Here
4 Simple Steps To Brush Plate Your Small Parts
1. Plug In The Adapter | ![]() |
2. Clip the Black Lead To The Part | ![]() |
3. Soak The Wand With Bandage In the Solution | ![]() |
4. Brush The Wand Over The Cleaned Part | ![]() |
Plug N' Plate® is a new concept in plating small parts. Our unique mains power pack supplies just the right amount of power allowing you to brush, and in some situations, dip plate your smaller components.
The Plug N' Plate® system will also allow you to patch repair areas where the original plating has worn away.
Plug N' Plate® is ideal for vintage vehicle restorers, antique collectors and dealers, and small workshops doing prototype work.
What could be simpler? The Plug N' Plate® wand is attached to the red plug on the Power Pack, and the alligator clip is attached to the work-piece. The end of the wand is covered in an absorbent bandage, which is soaked in the plating solution for a few seconds.
By simply stroking the part with swift brush strokes, the circuit is closed and the plating metal bearing solution goes to work, depositing its beautiful layer onto the object.
Plug N' Plate® is perfect for gold plating car emblems. Simply strip the chrome off with Chrome Stripper, then apply the gold. Full instructions are included.
Plug N' Plate® may be applied onto most metals. To see which kit plates onto which metal, read our instruction booklet. To plate onto Stainless Steel, use the Plug N' Plate® Copper system. When gold plating onto stainless, apply our Stainless Steel Activator For Gold with a stainless wand and 4.5V power pack, then you may gold plate directly onto the stainless part.
Aluminum can be plated with the Acid Copper Plug N Plate system, after prepping your part with Zincate.
Plastic parts can also be plated with our Acid Copper Plug N Plate system after painting with conductive paint and swabbed with Tinning Solution.
* - Manufacturer Direct Pricing. Plug N' Plate® is a registered trademark of Caswell Inc.
Plug N Plate Workshop Kit Contains:
- 1 x Plug N' Plate® Power Supply 4.5V
- 1 x Plug N' Plate® Power Supply 1.7V
- 1 x 8oz Nickel Solution
- 1 x 8oz Copper Solution
- 1 x 8oz Copy Chrome™ Solution
- 1 x 4oz Brass Solution
- 1 x 4oz Silver Solution
- 1 x 4oz Gold Solution
- 1 x 8oz Black Krome™ Solution
- 1 x 8oz Zinc Solution
- 1 x 8oz Bronze Solution
- 1 x 8oz Tin Solution
- 6 x SS Brush Plating Wands
- 1 x Brass Brush Plating Wand
- 1 x Copper Brush Plating Wand
- 1 x Zinc Brush Plating Wand
- 1 x Tin Brush Plating Wand
- 10 x Wand Bandages
- 3 x assorted pen plating wands
- 1 x Instruction Booklet
- Free Technical Support
Hazardous Shipping Info
GHS Info
SDS
Still works after 10 + years
I bought one of these kits over ten years ago for a patch job on a chrome muffler. Dug it out again and it still plates copper, nickle and Copy chrome wonderfully. I'm very satisfied with your product. Thanks
