Eliminate nickel plating steps and plate gold directly onto stainless steel parts using our Stainless Steel Activator for Gold. Etch with this product, then plate gold directly onto stainless parts.
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
4 Reviews Hide Reviews Show Reviews
Great product!
We had a customers firearm in for a plating job and the plating solution wasn't bonding as expected (alloy). After applying the stainless activator to the parts it turned out as it should have.
Works as described
Used on ring , then gold plated it with no problem
nice!!!
stupid stainless steal, ill show you!
Stainless activator
It works as advertised.
