Plug N' Plate Nickel/Gold Kit
The great new way to brush plate small parts
Video: Title
Using The Caswell Plug N Plate Brush Plating Kit
Read An Article From Mac Life Magazine On Plating An iPod Using Our Plug N' Plate® Kits (372 KB PDF)
Read the Instruction Manual Here
4 Simple Steps To Brush Plate Your Small Parts
1. Plug In The Adapter | ![]() |
2. Clip the Black Lead To The Part | ![]() |
3. Soak The Wand With Bandage In the Solution | ![]() |
4. Brush The Wand Over The Cleaned Part | ![]() |
Plug N' Plate® is a new concept in plating small parts. Our unique mains power pack supplies just the right amount of power allowing you to brush, and in some situations, dip plate your smaller components.
The Plug N' Plate® system will also allow you to patch repair areas where the original plating has worn away.
Plug N' Plate® is ideal for vintage vehicle restorers, antique collectors and dealers, and small workshops doing prototype work.
What could be simpler? The Plug N' Plate® wand is attached to the red plug on the Power Pack, and the alligator clip is attached to the work-piece. The end of the wand is covered in an absorbent bandage, which is soaked in the plating solution for a few seconds.
By simply stroking the part with swift brush strokes, the circuit is closed and the plating metal bearing solution goes to work, depositing its beautiful layer onto the object.
Plug N' Plate® is perfect for gold plating car emblems. Simply strip the chrome off with Chrome Stripper, then apply the gold. Full instructions are included.
Plug N' Plate® may be applied onto most metals. To see which kit plates onto which metal, read our instruction booklet. To plate onto Stainless Steel, use the Plug N' Plate® Copper system. When gold plating onto stainless, apply our Stainless Steel Activator For Gold with a stainless wand and 4.5V power pack, then you may gold plate directly onto the stainless part.
Aluminum can be plated with the Acid Copper Plug N Plate system, after prepping your part with Zincate.
Plastic parts can also be plated with our Acid Copper Plug N Plate system after painting with conductive paint and swabbed with Tinning Solution.
* - Manufacturer Direct Pricing. Plug N' Plate® is a registered trademark of Caswell Inc.
Plug N Plate Nickel/Gold Kit Contains:
- 1 x Plug N' Plate® 4.5V Power Supply
- 1 x 8oz Nickel Solution
- 1 x 4oz Gold Solution
- 2 x SS Brush Plating Wand
- 2 x Wand Bandages
- 1 x Instruction Booklet
- Free Technical Support
GHS Info
SDS
3 Reviews Hide Reviews Show Reviews
Great Value for the money
I couldn't have been happier with this kit, I had searched for weeks trying to find a solution to a dilemma I had on a part that the gold had worn completely off of. I had several other matching parts that went along with this one so it was really bothering me that this part was a different color (OCD) I guess lol, but anyway this far exceeded my expectation, was extremely easy to use, and I am well, pleased. As soon as some others seen it they wanted me to do some of their things. I am retired and on disability and may have found myself a new hobby. Thanks to the people at Caswell for all their knowledge and help~!
Worked well
The kit was effective and easy to use. I wish they included more gauze.
Best Kit to Buy
As I learned more about goldplating and wanted to start a hobby, I found this kit. It is the cheapest I've found and has made me very happy starting a great new hobby. I gift my family gold items for holidays now. If you want to try goldplating for the first time, this is what you need to buy! I'd suggest to use it for immersion plating rather than brush plating.
