Quick view sku: R122418A 12W X 24L X 18H 20 GAL TANK MSRP: Now: $349.00 Add to Cart Compare Quick view Caswell sku: GLD415 24K Gold Tank Plating Kit - 2 Gal MSRP: Now: $1,450.89 Add to Cart Compare Quick view Caswell sku: NSP-2050 5 AMP CC RECTIFIER MSRP: Now: $213.40 Add to Cart Compare Quick view Caswell sku: ALDG Aluminum Degreaser Powder - 2lb Makes 3 Gallons MSRP: Now: $30.24 Add to Cart Compare Quick view Caswell sku: ANBANDG ANODE BANDAGE MSRP: Now: $1.64 Add to Cart Compare Quick view Caswell sku: STRP5 ANODIZE & CHROME STRIPPER - 8 OZ MSRP: Now: $7.69 Add to Cart Compare Quick view Metal-X sku: MXB9 B9 NICKEL STRIPPER - 2.5 LB MSRP: Now: $32.99 Add to Cart Compare Quick view Caswell sku: A865 Black Chromate Concentrate - 8 oz makes 1 Gal MSRP: Now: $36.29 Add to Cart Compare Quick view Caswell sku: BLKR1G Black Krome Plating Kit - 1 Gal MSRP: Now: $150.69 Add to Cart Compare Quick view Caswell sku: BLKR2G Black Krome Plating Kit - 2 Gal MSRP: Now: $279.39 Add to Cart Compare Quick view Caswell sku: BLKR4G Black Krome Plating Kit - 4 Gal MSRP: Now: $386.64 Add to Cart Compare Quick view Caswell sku: BKS1G BLACK KROME PLATING SOLUTION 1 GAL MSRP: Now: $100.64 Add to Cart Compare Quick view Caswell sku: BLKR8 BLACK KROME PLUG N' PLATE SOLUTION MSRP: Now: $15.94 Add to Cart Compare Quick view Caswell sku: BNK1 Black Nickel Plating Kit - 1.5 Gallon MSRP: Now: $240.89 Add to Cart Compare Quick view Caswell sku: BCC1Q BLUE CHROMATE CONCENTRATE - 1 QT MSRP: Now: $72.59 Add to Cart Compare Quick view 12W X 24L X 18H 20 GAL TANK HDPE Rectangular Plating Tank. Easily fits 15 gallons of plating solution. Dimensions: 12" Wide x 24" Long x 18" High Does not include cover. MSRP: Now: $349.00 Add to Cart Compare Quick view 24K Gold Tank Plating Kit - 2 Gal 24ct Gold Tank Plating Kits Work safely with cyanide free gold to plate jewelry, flatware, baby shoes, flowers, bathroom fittings and much more. Caswell 24ct Gold is ideal for immersion plating of larger items. For brush plating... MSRP: Now: $1,450.89 Add to Cart Compare Quick view 5 AMP CC RECTIFIER 5 Amp Constant Current Rectifier Ideal for small anodizing runs, small plating jobs. Will anodize parts up to 1 sq ft. Will nickel & copper plate parts up to 70 sq in. Other options: Wamptek Dr Meter Hanmatek MSRP: Now: $213.40 Add to Cart Compare Quick view Aluminum Degreaser Powder - 2lb Makes 3 Gallons This special degreaser for Aluminum quickly cleans any aluminum alloy without etching. Mix 2 lbs of cleaner with 3 gallons of distilled water in a stainless steel container. Heat to 130 deg F on a hotplate. Immerse aluminum parts for 3-10 minutes prior... MSRP: Now: $30.24 Add to Cart Compare Quick view ANODE BANDAGE Wraps around anode MSRP: Now: $1.64 Add to Cart Compare Quick view ANODIZE & CHROME STRIPPER - 8 OZ 8 fl oz of stripping solution. To strip anodize, immerse parts for 5-30 minutes. To strip chrome, use a stainless steel wand and 12V DC. Contains Hazardous Goods. Shipping restrictions apply. Ground shipping only to the Continental USA. Please call +1... MSRP: Now: $7.69 Add to Cart Compare Quick view B9 NICKEL STRIPPER - 2.5 LB NO ELECTRICITYNO CYANIDESNO PHOSPHATESNO CAUSTIC AMINESNO AMMONIANO FUMES The only one-component, non-toxic, powdered, immersion nickel strippers on the market. Removes NICKEL from steel, copper, brass and zinc diecast, silver and gold. Caswell Inc... MSRP: Now: $32.99 Add to Cart Compare Quick view Black Chromate Concentrate - 8 oz makes 1 Gal BLACK CHROMATE Our Black Chromate concentrate provide a true black chromate on zinc or cadmium plated parts. It is especially effective for chromating bolt parts such as nuts, bolts and various fasteners. Immerse plated parts for 15-40 seconds, depending... MSRP: Now: $36.29 Add to Cart Compare Quick view Black Krome Plating Kit - 1 Gal Black Krome™ Kit This spectacular product will add style and elegance to many products. Safe to use. Contains no chrome or nickel. Ideal for vehicle trim, guns, musical instruments, fishing lures, etc. The system plates within a couple of minutes over a... MSRP: Now: $150.69 Add to Cart Compare Quick view Black Krome Plating Kit - 2 Gal Black Krome™ Kit This spectacular product will add style and elegance to many products. Safe to use. Contains no chrome or nickel. Ideal for vehicle trim, guns, musical instruments, fishing lures, etc. The system plates within a couple of minutes over a... MSRP: Now: $279.39 Add to Cart Compare Quick view Black Krome Plating Kit - 4 Gal Black Krome™ Kit This spectacular product will add style and elegance to many products. Safe to use. Contains no chrome or nickel. Ideal for vehicle trim, guns, musical instruments, fishing lures, etc. The system plates within a couple of minutes over a... MSRP: Now: $386.64 Add to Cart Compare Quick view BLACK KROME PLATING SOLUTION 1 GAL Use to replenish or add onto an existing Black Krome plating kit. Use as is. Do not dilute. MSRP: Now: $100.64 Add to Cart Compare Quick view BLACK KROME PLUG N' PLATE SOLUTION Brush plate with a stainless steel wand and 4.5V DC MSRP: Now: $15.94 Add to Cart Compare Quick view Black Nickel Plating Kit - 1.5 Gallon Black Nickel Plating Kit This kit gives a beautiful translucent Black Nickel coating over most metals including nickel, copper, brass, tin, steel, stainless steel and zinc. Mix up the chemicals with distilled water, clean your parts with the included... MSRP: Now: $240.89 Add to Cart Compare Quick view BLUE CHROMATE CONCENTRATE - 1 QT BLUE CHROMATE Our blue chromate concentrate produces a true blue conversion coating on zinc plated items. It is a single dip blue trivalent chromate that offers high salt spray resistance for up to 130 hours to white rust corrosion, and 160-200 hours to... MSRP: Now: $72.59 Add to Cart Compare 1 2 3 4 5 6 Next 1 2 3 4 5 6 Next Compare Selected × OK
