NO ELECTRICITY
NO CYANIDES
NO PHOSPHATES
NO CAUSTIC AMINES
NO AMMONIA
NO FUMES
The only one-component, non-toxic, powdered, immersion nickel strippers on the market.
Removes NICKEL from steel, copper, brass and zinc diecast, silver and gold.
Caswell Inc. distributes three MetalX Nickel Strippers:
- MetalX B-9 strips nickel from steel, without etching the base metal.
- MetalX B-929 strips nickel from copper, brass, zinc diecast, pot metal, silver and gold, without etching the base metal.
- MetalX B-913 strips nickel from aluminum, without etching the base metal.
MetalX strippers will strip nickel at the rate of 2 mils per hour, and will strip 2.5-6 ounces of nickel per gallon of stripper solution. Electroless nickel will strip at the same rate, providing the phosphorous content does not exceed 5%. Higher phosphorous electroless nickel will take longer to strip.
- 2.5 lbs of MetalX stripper makes 1 gallon of stripping solution.
- Use plastic, unlined steel or stainless steel tanks
- Agitation is required during stripping
- Stripping tank must operate between 120°F-150°F. To prolong bath life, heating should be discontinued immediately after stripping is complete.
- Stainless steel or titanium heaters must be used. No quartz or ceramic heaters.
- Instruction sheet will be provided with purchase.
GHS Info
SDS
11 Reviews Hide Reviews Show Reviews
B9 nickel stripper
The B9 stripper works great, I mix up a small batch and soak my items overnight and then easily blast away anything hanging on the next day.
B9 Nickel Stripper
Excellent stripper! Goes a long way. I used in a ceramic crock pot. Somewhere on website or maybe in the instructions, it says not to do that, however, it worked for me several times. It removed the nickel from golf iron heads in a couple of hours. Great instructions for all Caswell products. Highly recommend this and other Caswell products. Only brand I use when it comes to chrome or nickel stripping. I also highly recommend their black oxide kit.
Nickel stripper
product worked just as promised. I would use it again if needing to strip nickel plating.
Great product
Worked great with the suggestions of other users
Works great!
This stuff works exactly as described. I stripped some nickel off of an old gun action and it took every spec off in just a couple hours. Another review mentioned a smell, but it wasn't this stuff, it is almost odorless. I soaked my parts in a stainless ultrasonic tank because it has a heater. When the parts were done I turned on the ultrasonic and it removed the most of the smut. I then rinsed it off with hot water. I put off this project a long time because I didn't want to mess with acids and electricity, I wish I found this sooner!
Excellent
Your product arrived and performed as advertised. Completely satisfied.
Worked great, thank you.
Removed everything I needed removed.
Used to strip old gun
Did the job like advertised
