Aluminum Degreaser Powder - 2lb Makes 3 Gallons
This special degreaser for Aluminum quickly cleans any aluminum alloy without etching. Mix 2 lbs of cleaner with 3 gallons of distilled water in a stainless steel container. Heat to 130 deg F on a hotplate. Immerse aluminum parts for 3-10 minutes prior to anodizing or zincating. Rinse after use and check cleanliness with the waterbreak test.
GHS Info
SDS
4 Reviews Hide Reviews Show Reviews
Wow
Takes any and all grease right off the part.
Great product
Fast shipping!
Great
Thank you!
Aluminium degreaser
The degreaser works great after giving a good finish polish.
