Black Krome™ Kit
This spectacular product will add style and elegance to many products. Safe to use. Contains no chrome or nickel.
Ideal for vehicle trim, guns, musical instruments, fishing lures, etc.
The system plates within a couple of minutes over a nickel or copper base. To plate over chrome, the existing chrome plate must be removed by stripping with Anodize & Chrome Stripper.
Black Krome™ can be plated by brush plating or by an immersion technique.
Black Krome will plate over Nickel, Copper, Steel, Tin & Lead.
For brush plating, a 4.5 volt power supply and a stainless steel wand is required. Immersion plating requires 0.24 amps per square inch at 3-7V.
For tank (immersion) plating, the solution is best used at 140 deg f, using a stainless steel anode. Because the plate is derived from the solution and not the anode, the solution will need to be replaced periodically.
When plating over nickel, the color will have a metallic smoky black look, whereas over copper, a darker black will be achieved.
The finish should be waxed with Collinite Insulator or Metal Wax, or clearcoated.
4 Gallon Kit Contains:
- 1 x 5 Gal Tank and Lid
- 2 x Stainless Steel Anode
- 4 Gal Black Krome™ Solution
- Caswell Plating Manual
- Free Technical Support
- NO HEATERS INCLUDED
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
SDS
5 Reviews Hide Reviews Show Reviews
great kit
Look really good on my 45 highly recommended
nice set up
And a great kit.easy to use I am very pleased.
awesome kit
Great kit works Good looks even better
great kit
Highly recommended
Going to increase my tank size by ordering this kit
The black chrome is so cool, I am going to order this larger kit soon to increase the side of my tank so I can do larger parts. A++++
