Black Chromate Concentrate - 8 oz makes 1 Gal
BLACK CHROMATE
Our Black Chromate concentrate provide a true black chromate on zinc or cadmium plated parts. It is especially effective for chromating bolt parts such as nuts, bolts and various fasteners. Immerse plated parts for 15-40 seconds, depending on the desired depth of color. Rinse in fresh water to stop the process, and dry with hot air (150 deg F).
Black Chromate is a two part solution. Mix with distilled water. 8oz makes 1 gallon of mixed chromate.
Hazardous Shipping Info
SDS
7 Reviews Hide Reviews Show Reviews
Does What it Says
Blackens my zinc plated hinges and latches in seconds. Easy to work with; good product.
Solid for Zinc Plated Machine Screws!
Could not find any black oxide machine screws in the sizes I need.. Needed black machine screws for appearance.. Found this product and it really work amazing.. Just what I needed.. I saw someone commenting on a greenish color.. That is just a residue, I believe, that can be easily wiped off...
so cool
love this product so much more the gun metal blackening processes, the hues in the black are just to cool, great product
Your never gonna beat caswell products
Caswell, best in the business when it comes to plating.
not bad!
not really pure black look but have a tinged of like kinda dark green.
awesome products! I always have the best looking finishes when using your products!
great product
Perfect for restoring automotive hardware.
