Black Nickel Plating Kit
This kit gives a beautiful translucent Black Nickel coating over most metals including nickel, copper, brass, tin, steel, stainless steel and zinc.
Mix up the chemicals with distilled water, clean your parts with the included degreaser and then hang into the Black Nickel solution. Plate for 2-10 minutes at 0.01 amps per square inch.
Low amperage requirements mean you can plate larger objects with a small rectifier. For example, a part about the size of an orange (100 square inches) would only require 1 amp to plate.
The 1.5 Gallon Kit Contains:
- 2 x 2 Gallon Tanks
 - 1 Pack Black Nickel Powder (Makes 1.5 Gallons)
 - 1 Pack SP Degreaser (Makes 2 Gallons)
 - 2 x 6" x 8" Nickel Anodes & Bandages
 - Circulation Pump
 - Instructions
The depth of color can be modified slightly by increasing the amperage. Higher amps provide a more solid black color.
The kit does not contain any Hazardous Goods and can be shipped anywhere.
                Recommended Skill Level
                    Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
GHS Info
SDS
So easy, make it fun
This kit may not have every this you need , but takes you into what you need to get started, I went all out and now with the help from on line live, I have a great plating system and I am moving up to silver and maybe gold this is a great add to my business.
