ANODE BANDAGE
Wraps around anode
4 Reviews Hide Reviews Show Reviews
Excellent product
I've tried other filter fabrics but I keep coming back to the original material supplied with the kits.
Best available
Have not been able to find these any place else. I got enough to last me a long time.
Good stuff....
Tried to find alternatives to this material but there are none, so I keep a small supply in stock at all times....
