10 Amp Constant Current Rectifier
Ideal for small anodizing runs, small plating jobs.
Other options:
7 Reviews Hide Reviews Show Reviews
Great product
I serouly reseached extesivly online for about a week and this was the best Rectifier this size for what I was looking for and at a great deal. Love how slim an compact it is and the features are great.
Great power supply in tight package.
Can't say enough about this rectifier. It took a while to ship; Caswell kept me informed about the delay and ship date, but well worth it. No more tweaking power supply as the part goes through anodize build up. Just set it and let it go. Good protection, too, against a short. Worth it to me just to free up having to check constantly on the current and voltage during processing.
5 amp unit
good little unit for small parts
Nickel plating
This rectifier is well made, has a steel case, works perfectly. It allows the user to dial in the exact amps needed for perfect plating results. Worth every penny. This unit is an integral part of a well-working small plating set up.
Works perfect
Set it to the proper amps for the area and it works flawlessly.
cad plating
the energy source is simple and easy to use with the kit
don't bother with a battery charger!
being able to dial in the volts and amps is a great help and allows for consistent results.
