BLUE CHROMATE
Our blue chromate concentrate produces a true blue conversion coating on zinc plated items. It is a single dip blue trivalent chromate that offers high salt spray resistance for up to 130 hours to white rust corrosion, and 160-200 hours to red rust corrosion. No additional topcoat is required to obtain this high degree of corrosion resistance. It produces a beautiful blue/clear trivalent chromate to meet automotive and all other industrial standards.
Dip zinc plated parts at room temperature for 15-40 seconds. For best results, dry with hot air (150 deg F)
Mix 1 part Blue Chromate to 4 parts Distilled Water, ie. 1 Quart Makes 1.25 Gallon Mixed
Hazardous Shipping Info
GHS Info
SDS
7 Reviews Hide Reviews Show Reviews
this suff is cool
Looks good and last longer than I figured it would will buy again
simply awesome
Great buy and works well
man this works great
I highly recommended this to anyone
awesome
Really works and looks good to highly recommended to buy
loved it
I got this and works really well very pleased.
nice!
This is a must and works really good highly recommend
works
I use this and it really works and looks great A+
