Black Krome™ Kit
This spectacular product will add style and elegance to many products. Safe to use. Contains no chrome or nickel.
Ideal for vehicle trim, guns, musical instruments, fishing lures, etc.
The system plates within a couple of minutes over a nickel or copper base. To plate over chrome, the existing chrome plate must be removed by stripping with Anodize & Chrome Stripper.
Black Krome™ can be plated by brush plating or by an immersion technique.
Black Krome will plate over Nickel, Copper, Steel, Tin & Lead.
For brush plating, a 4.5 volt power supply and a stainless steel wand is required. Immersion plating requires 0.24 amps per square inch at 3-7V.
For tank (immersion) plating, the solution is best used at 140 deg f, using a stainless steel anode. Because the plate is derived from the solution and not the anode, the solution will need to be replaced periodically.
When plating over nickel, the color will have a metallic smoky black look, whereas over copper, a darker black will be achieved.
The finish should be waxed with Collinite Insulator or Metal Wax, or clearcoated.
1 Gallon Kit Contains
- 1 x 2 Gal Tank and Lid
- 1 x Stainless Steel Anode
- 1 Gal Black Krome™ Solution
- Caswell Plating Manual
- Free Technical Support
- NO HEATERS INCLUDED
Recommended Skill Level
Intermediate level products require some extra work before use, or multiple steps to achieve end results. Intermediate level products can certainly be used by novices, but extra time, patience and research will greatly help get great results.
SDS
8 Reviews Hide Reviews Show Reviews
my dad loves it
He said it was easy to use and worked very well..
very happy with my kit
Plates really well I had no problems with my kit will buy again!!!
very happy custmer
Great kit, east and ready to plate
great look
Awesome kit, simple to use
nice kit
Love how it looks. And was easy to use great kit.
nice kit
Highly recommended !!!
Love the Black Chrome kits
They work awesome and leave a plated surface that everyone likes.
Great product
Works great, looks awesome when plating over nickel
