null
Get Our Booklet
Buffing Kits
  • 3/4 HP Buffing Machine Kit - 3450 RPM
    Includes Heavy Duty 3/4HP 3450 RPM Buffer, wheels and compounds for any metal. Each unit is equipped with a strong, powerful motor that supplies the necessary torque for start-up and operation under load Large diameter armature shaft with shielded...
    $329.99
    Add to Cart
  • 3/4+hp Motor Buffing Kit 10"
    3/4+hp Motor Buffing Kit 10" x 7/8" face 2 x Sisal Wheels 2 x Loose (1/2" Face) Wheels 2 x Spiral Sewn 1 x Buffing Rake 6 x JUMBO Bars Compound (one of each) How to Buff & Polish Booklet
    $136.39
    Choose Options
  • 3/4+hp Motor Buffing Kit 8"
    3/4+hp Motor Buffing Kit 8" x 7/8" face 2 x Sisal Wheels 2 x Loose Wheels (1/2" Face) 2 x Spiral Sewn 1 x Buffing Rake 6 x JUMBO Bars Compound (one of each) How to Buff & Polish Booklet
    $124.84
    Choose Options
  • Advanced Straight Razor Polishing Kit
    Mid Speed 1100RPM Buffers are ideal for polishing straight razors. The kits include all the wheels and buffing compound you will need to polish straight razors in three buffing steps, starting with black compound, then green, then white. The Advanced Kit...
    $458.69
    Add to Cart
  • Airstream Polishing Kit Airstream Polishing Kit
    Polish Airstream Trailers With A Drill or Grinder Every Airstream Camper owner dreams of their trailer shining like it was when it left the showroom floor. With our Airstream Polishing Kit, dreams become possible. The all aluminum exterior of Airstream...
    $144.09
    Add to Cart
  • Aluminum & Copper Alloy Polishing Kit Aluminum & Copper Alloy Polishing Kit
    Kit Includes: 1 x Medium Mushroom Buff 1 x Small Mushroom Buff 1 x Arbor Adapter 1 x 4" Sisal Wheel 1 x 4" Spiral Sewn Wheel 1 x 4" Loose Cotton Wheel 1 x 1.5" x 1" Bullet Bob 1 x Large Brown Compound 1 x Large Black Compound 1 x 8 ox White Rouge Liquid...
    $60.49
    Add to Cart
  • Aluminum Wheel Finishing Kit
    Whether your wheels have been clear coated or anodized, this kit contains the chemicals to remove both types of coating prior to polishing. The kit contains: 1 pack Anodize Stripper makes 3 gals 1 bar Greaseless Compound 120 grit 1 bar Greaseless...
    $141.89
    Add to Cart
  • Arbor Kit
    Arbor Kit
    These smaller 4" diameter wheels are ideal for getting into those more awkward places, where you need to take the power to the part. Polish on the vehicle, using an electric drill or die grinder as the power source. The arbor has a 1/4" diameter shaft...
    $18.69
    Add to Cart
  • Basic Straight Razor Polishing Kit
    $361.89
    Add to Cart
  • Benchtop Small Plastic Buffing Kit
    Now you can easily buff scratches and haze from plastics including CD's, eyeglass lenses, plastic auto moldings, and much more. First, buff the part with the heavy cutting buffing compound (white) and the loose cotton wheel. Finally, buff with the blue...
    $241.99
    Add to Cart
  • Buffing Machine With Chuck Kit
    Our 1/2HP Buffing Machine with a handy chuck tool, which threads onto the right shaft. Mount buffing wheels, felt bobs, shank mounted wheels, flap wheels and any shaft based tool quickly and easily. Buffing Machine Specifications: Heavy duty cast iron...
    $168.29
    Add to Cart
