These smaller 4" diameter wheels are ideal for getting into those more awkward places, where you need to take the power to the part.
Polish on the vehicle, using an electric drill or die grinder as the power source.
The arbor has a 1/4" diameter shaft.
Kit contains:-
- 1 x Arbor
- 2 x 4" Spiral Sewn Wheels
- 2 x 4" Sisal Wheels
- 2 x 4" Loose Wheels
