Our 1/2HP Buffing Machine with a handy chuck tool, which threads onto the right shaft. Mount buffing wheels, felt bobs, shank mounted wheels, flap wheels and any shaft based tool quickly and easily.
Buffing Machine Specifications:
- Heavy duty cast iron construction for vibration free operation
- CSA approved OSHA compliant
- 1/2 Inch Diameter Shaft
- 120V 5 amp draw / 240V 2.5 amp draw - Single Phase
- 22 lbs
- 3 Year Warranty
Kit includes :
- 1 x 1/2 HP buffing machine with two extra long shaft extenders
- 1 x 1/2" Chuck Adapter
- 1 x 6" Spiral Sewn Cotton Wheel
- 1 x 6" Loose Cotton Wheel
- 1 x 4" Spiral Sewn Cotton Wheel
- 1 x 4" Loose Cotton Wheel
- 1 x 1" Wide x 2" High x 1/4" Shaft Bullet Felt Bob
- 1 x 3/4" Wide x 1.5" High x 1/4" Shaft Cylinder Felt Bob
- 1 x 1" Wide x 1" High x 1/4" Shaft Dome Felt Bob
- 1 x 3/4" Wide x 1" High x 1/4" Shaft Ballon Felt Bob
Recommended Skill Level
Beginner level products can and should be used by anybody, including those who consider themselves not crafty, handy or hands on. Most beginner level products can be used out of the box and can expect results within minutes. It is always important to read the product instructions and description on the web site before use, for example, nearly all of our plating kits require a polished and clean surface before plating.
Great product.
We use this mashine for buffing brass musical instruments and it's perfect. It's been a pleasant experience doing business with Caswell.
