Advanced Straight Razor Polishing Kit
Mid Speed 1100RPM Buffers are ideal for polishing straight razors.
The kits include all the wheels and buffing compound you will need to polish straight razors in three buffing steps, starting with black compound, then green, then white.
The Advanced Kit also includes a blue compound for extra fine buffing, and greaseless compounds for more precision polishing.
A wheel rake is included to clean the wheels.
Stands for the buffers are also available.
Advanced Kit includes:
- 1100RPM, 3/4HP Buffer
- 3 x 4" Sisal Wheels
- 3 x 6" Sisal Wheels
- 4 x 4" Spiral Sewn Cotton Wheels
- 4 x 6" Spiral Sewn Cotton Wheels
- 2 x 8" Loose Cotton Wheels
- Black, Stainless, White & Blue Compounds (Jumbo Size)
- 80, 120, 240 & 400 Grit Greaseless Compounds
- 1 x Extra Fast Cut Stainless Compound (Jumbo)
- Wheel Rake
- Instructions
Great offerings from a stand up company for advanced straigt razor buffing kit
It's a great machine with plenty of toys to keep you busy, Very well built heavy duty buffer! Here are reasons I did not give it 5 stars. I wasn't impressed with Straight razor buffing guide. I was disapointed in it. Doesn't even mention straights or tips N ticks that specially work for straights. Pictures of item being buffed is a bolt. Its very genricly written. If your a newb to buffing you will benefit from guide. Also the loose cotton wheels grab at the full hollows. I has read this elsewhere and was prepared for it. It gets worse after cleaning wheels too. They should make half if not all loose cotton wheels be hard felt wheels to eliminate the grabbing action. I have reals that's what most do to avid the issue. You get a lot for this kit but the not having the one higher grit greaseless compund an the dsrker green bar is disappointing. I am saying its necessary to have em. But times they would be perfect for the step I'm at. Again very pricey kit and I get they need to make money so do smaller ones of em but include em so don't have to be wanting em right of bat. After what I spent, I can't justify it for near future. Again after I Get em, I admit may say it was a waster of money but everyhing I'm buffing serves a purpose!!! I doubt you could put such a kick butt kit together as Caswell has done!!!! I previously bought a cheap buffer , by time ingot a few wheels and some compunds that weren't all the hype they deservesd I was quickly over a hundred dollars and easily would have doubled plus that! You buy this kit/set up and bam your up n running and very littke to want/need or complain about. I would recomend this buffer and Caswell to friends m family. It makes wry easy work of buffing!!!!!!
