1/4 - 1/3hp Motor Buffing Kit
1/4 - 1/3hp Motor Buffing Kit 6" x 1/2" face
- 2 x Sisal Wheels
- 2 x Loose Wheels
- 2 x Spiral Sewn
- 1 x Buffing Rake
- 6 x Large Bars Compound (one of each)
- How to Buff & Polish Booklet
6 Reviews Hide Reviews Show Reviews
New to this process
Restoring a 51 Ford, time to buff and polish the stainless steel trim. This is an excellent source of information for the 1st timer.
very complete kit......
been using the heck out of my wheels and compound since it arrived. can't wait to order my plating kit.
Perfect Polishing Kit
This kit includes everything that you need to make aluminum look better than ever before.
Everything you need to get started!
I purchased this kit to start learning and honing my alum. and steel polishing skills after I set up my buffing wheel. This kit seems to have everything you need to produce a great finish. The multiple wheels and compounds it includes are enough to polish any surface, even plastics! I would recommend this kit for the beginner or hobbyist.
Everything you need!
What else can I say, everything you need is here to try out and find out what works best for your needs, highly recommend this product.
very good product
very good product
