Kit Includes:
- 1 x Medium Mushroom Buff
- 1 x Small Mushroom Buff
- 1 x Arbor Adapter
- 1 x 4" Sisal Wheel
- 1 x 4" Spiral Sewn Wheel
- 1 x 4" Loose Cotton Wheel
- 1 x 1.5" x 1" Bullet Bob
- 1 x Large Brown Compound
- 1 x Large Black Compound
- 1 x 8 ox White Rouge Liquid Polish
- Instructions
This kit has been specially designed for polishing motorcycle and small engine parts using electric drills.
The Liquid WHITE ROUGE polish should be wiped onto the surface with a cloth, then buffed off using any wheel, bob or mushroom buff.
The sisal wheel is designed for aggressive cut down or scratch and buff mark removal using the black compound.
5 Reviews Hide Reviews Show Reviews
good service good product
thank you
thank you
Very Happy
Product bought luster back to old brass hardware, look new. Very fast shipping and great customer services, helped me pick out the right product for the solution.
Very Happy
Makes Polishing Quite a Bit Easier
Good product. Comes with several different buffing wheels to get in all the nooks and crannies!
