3/4 HP Buffing Machine Kit - 3450 RPM
Includes Heavy Duty 3/4HP 3450 RPM Buffer, wheels and compounds for any metal.
- Each unit is equipped with a strong, powerful motor that supplies the necessary torque for start-up and operation under load
- Large diameter armature shaft with shielded bearings for smooth operation
- Heavy duty cast iron construction for vibration free operation
- CSA approved OSHA compliant
- 5/8 Inch Diameter Shaft
- 120V 8 amp draw / 240V 4amp draw - Single Phase
- 3 Year Warranty
Kit contains:
- 1 x 3/4hp buffer - 3450 RPM
- 2 x 8" x 1/2" Spiral Sewn Wheels
- 2 x 8" x 1/2" Sisal Wheels
- 2 x 8" x 1/2" Loose Cotton Wheels
- 2 x 8" x 1/2" Canton Flannel Wheels
- 2 x 4" x 1/2" Spiral Sewn Wheels
- 2 x 4" x 1/2" Sisal Wheels
- 2 x 4" x 1/2" Loose Cotton Wheels
- 2 x 4" x 1/2" Canton Flannel Wheels
- 1 x six pack Assorted Jumbo Buffing Compounds
- 1 Wheel Rake
3 Reviews Hide Reviews Show Reviews
Need to have this
I dont currently own this set but I used one that a friend owns and it works great, I will be putting in an order ASAP.
Great company to work with
Great deal and delivered quickly - will definitely be back!
Pleasure to do business with.
Heavy duty enough for my home shop needs.
